Gui Vaccaro avatar image
Gui Vaccaro asked Gui Vaccaro commented
How can one set-up time-table Down or Resume behaviors programatically?
I need to create a large number of time-tables to control shifts and operator groups. For each time-table, I need to set the associated group behaviors to "Travel To Object, Delay Until Down Time Complete" and select the destination object (different for each group). How can this be done via ProcessFlow or FlexScript?
Thank you!
FlexSim 24.2.2
custom codetimetable
Joerg Vogel avatar image
Joerg Vogel answered Gui Vaccaro commented
You can call user defined node function that has parameters.
You can try to call your timetable function again by node function call to node of “c”.
Maybe you have noticed this kind of call of a node in ownerobject(c) to declare current object in a code.
You call a process flow sub flow by executesubflow.
Or you create a token in an activity.
Gui Vaccaro avatar image Gui Vaccaro commented ·
It turns out you could, would, should do all that, but the answer is simpler. Just attribute a snippet of code the to function, as a string:
