I’m trying to calculate the cycle time for each AGV. I created a calculated table to get the difference between the start control point and the end control point. However, the problem is that the row keeps getting updated each time the AGV passes through these control points, so I don’t get the correct values. The same issue occurs with the takt time. Any suggestions?
Thank you !
cycletime and takttime values.fsm
