Jesús Evangelista avatar image
Jesús Evangelista asked Jesús Evangelista commented
Need to get a state chart or state percentaje of each location.
Hello!
In a model I'm developing I used some locations (Kiosks) to simulate time checkers. The logic was developed in Process Flow.
Now I need to get the utilization of EACH Kiosk in a Dashboard. A state chart, such as the normal ones, would be perfect. I tried to add the chart, using the Healthcare environment (using the location state chart list), and it worked, but shows the states of ALL locations.
Is there an easy way to get what I need? Getting the percetaje state of each location.
Thank you in advice! :)
FlexSim 24.2.0
utilizationchartslocationshealtcharelocation states
Regan Blackett avatar image
1 Like"
Regan Blackett answered Jesús Evangelista commented
Hi @Jesús Evangelista. I think you should be able to get what you are looking for by selecting "Each member of each group" from the "Incluide data for" menu in the dashboard properties.
Like this:
Just make sure your Kiosks in a Group.
Jesús Evangelista avatar image Jesús Evangelista commented ·
It worked perfectly. Thank you!
