Example :
It is this result that I would like to retrieve in a Global Table and convert into time but I cannot display it in a Global Table.
Maybe you could use a Composite State chart:
In the screenshot below, the breakdown time from the composite state chart is 442 seconds:
Which is actually the sum of the breakdown times of processors 1 and 2 (124 + 318).
I attach the sample model if needed.
Good morning,
thank you for your response.
this solved my problem.
11 People are following this question.
