Is there a way to access "Attribute tree" in code.I tried using DOT function but no result.
br
Arun
br
Arun
Many of the attributes can be accessed through the "attrs" property.
In a path string, entering an object's attributes is done through ">" (Model.find("Processor1>stats"), for example). See the documentation on the "find" method for more information about how to traverse the model tree.
When the node text is blue you can also use that name as a keyword, passing in the object eg:
behaviour(current)
Hi Jason,
Can you give me a sample code so that i can build, lets say we check
1. "global instance" value = Available: size (Red Box)
2. "content" value (green box)
Test.fsm
Arun
12 People are following this question.
