Anutt K avatar image
Anutt K asked Jeanette F commented
Task Executer go to incorrect destinatin by process flow logic
Hello. In this model I have create process flow logic for Task Executer.
I use unload at object by case. I the correct when TE1 have assigned order it should to unload at Q1 by go to Q1's NN connected.
At first Outbound order of TE1 it can work normaly.
But, When the second Outbound order of TE1 it should to unload at Q1 same as last order before. So, in this time the software have notify about NN connection to NN247. But NN247 is be NN of Q2. The TE1 shouldm's go to Q2.
What worng withe the model logic. I have attached model here. Than You.
4 Way Shuttle.fsm
FlexSim 23.0.14
processs flownetwork nodeslogicunload
4-way-shuttle.fsm (110.2 KiB)
Hi @Anutt K, was Arun Kr's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
Arun Kr avatar image
Arun Kr answered Arun Kr edited
Using a Travel activity + Move object activity instead of unload will solve the issue. Not sure why the unload activity is creating the travel destination issue.
