I have this example model can you please help me with exporting data on run stop trigger. What should be the flexscript?
You can either trigger the export of all defined exports like this:
Object dbConnector=Model.find("Tools/DatabaseConnectors/DatabaseConnector1"); function_s(dbConnector,"exportAll");
Or trigger a single export:
Object dbConnector=Model.find("Tools/DatabaseConnectors/DatabaseConnector1"); treenode dbexport=variables(dbConnector).subnodes["exporters"].first; // the first in the list of exports. function_s(dbConnector,"exportSingle",dbexport);
Since it uses function_s calls, you may need to revise this code in the future, so if you need to invoke it in many places I'd place it in a user command and call that from multiple places instead.
Thank you for the answer. Can you please explain how we can create subnodes (like exporters) as you mentioned for the script?
14 People are following this question.
