Willie Chung avatar image
Willie Chung asked Felix Möhlmann commented
profiling the task sequence Error
In the model, I use the Preempt ProcessFlow to represent the process of Machine Breakdown, and I hope to use tokens to allow personnel to determine which machine is experiencing a malfunction, an error occurred in the model like pic. Any ideas on how I can use it successfully?
Thank you.
The File:Question.fsm
FlexSim 23.0.0
preemptiontoken labeltravel task
question.fsm (85.9 KiB)
Felix Möhlmann answered Felix Möhlmann commented
The travel task is missing a valid destination. The token is probably missing a label or the label has an invalid value or there you might have mistyped the label name.
The model was not successfully uploaded, so I currently can't do more than make these guesses.
· 10
Willie Chung avatar image Willie Chung commented ·
@Felix Möhlmann Hello,I re-uploaded the model.
Question.fsm
Felix Möhlmann avatar image Felix Möhlmann Willie Chung commented ·
You are telling the operator to travel to the preempted token, which of course can't work.
Willie Chung avatar image Willie Chung Felix Möhlmann commented ·
@Felix Möhlmann The model is operational, but a new issue has arisen because of the split, which splits the original token, so the Breakdown prcoess cannot preempt it. Is there a idea to preempt the split tokens?
1706175685095.pngThe file:Question.fsm
question.fsm (89.9 KiB)
