hi guys!
I want to output the content of this data in string format using code.As shown in the following image. What do I need to do?
Thank you for your review
hi guys!
Try something like this:
Table.query("SELECT StatisticsCollector.getPathFromID(Object),State,Time, Utilization FROM [State Collector]").cloneTo(Table("temp"))
treenode data = Model.find("Tools/StatisticsCollectors/StatisticsCollector1>stats/data");
string directory = modeldir();
if (!directory.length)
directory = documentsdir();
string fileName = getfilebrowse("*.csv", "Comma Separated Format", "", directory, 1);
exporttable(data, fileName, 1, 0);
Hi,thank u.
but I don't want to save this data as a file locally, I just want to convert it into string text
'Output' is meaningless unless you qualify the destination - most would assume a text file.
You can define this node with the type of the table, and then read every row and column in the table in the same way that the table reads, and write it into a text.
To define the table, see Jason's response above, or see the following:
Table data = Model.find("Tools/StatisticsCollectors/StatisticsCollector1>stats/data");
19 People are following this question.
