Steven Chen avatar image
Steven Chen asked Borja Lorenzo commented
excelexporttable() exports empty sheet for StatisticsCollector
Because build-in Excel interface won't clear the sheet before exporting, I tried to use custom export script like this:
string filePath = "D:\\Data.xlsx";
excelopen(filePath);
string sheetName = "Sheet1";
Table table = Table("StatisticsCollector1");
exceldeletesheet(sheetName);
excelcreatesheet(sheetName);
excelsetsheet(sheetName);
excelexporttable(table, 1, 1, table.numRows, table.numCols);
excelsave();
excelclose(0);
But excelexporttable() on StatisticsCollector exports empty sheet.
By the way,
Use build-in Excel interface to export StatisticsCollector has encoding issue, which was fixed for GlobalTable in FlexSim 18.0.7, but not fixed for StatisticsCollector.
Table("StatisticsCollector1").cloneTo("GlobalTable1") throw exception.
Perhaps you could provide an option to let user choose the character encoding?
FlexSim 23.2.0
statistics collectorexcel export
Jordan Johnson avatar image
1 Like"
Jordan Johnson answered Borja Lorenzo commented
The excelexporttable() command does not currently support exporting Statistics Collectors or Calculated Tables. I will add a request to the dev list to improve this feature.
The encoding issue is on the dev list already. I will links this report to that issue.
I will also add a report that cloning a stats collector to a global table throws exceptions.
· 2
Jordan Johnson avatar image Jordan Johnson ♦♦ commented ·
For exporting Statistics Collectors to Excel, you can use the Excel interface. The API could still be improved, however.
Borja Lorenzo avatar image Borja Lorenzo Jordan Johnson ♦♦ commented ·
The excelexporttable() command directly from a Statistics Collector in version 24.1 still results in an empty table. Is it still not possible? I have reviewed the update notes and found nothing related. I have resolved it by dumping the table from the Statistics Collector into a global table and then applying the command to that global table.
