Hello, I need help, I'm a beginner in flexsim. I have a processor that is fed by two conveyor belts that have a single conveyor output. I would like to make my processor only release the product when my station is empty.processor with station.fsm
To achieve this you can use the pre-defined trigger options to close and open the output of the processor (Add a trigger and choose "Control -> Close and Open Ports" from the pick options).
In this case, you would close the output whenever an item leaves the processor (On Exit).
And open it again once an item (which will be the one that previously left the processor) moves on from the station (On Continue)
In the attached model I use a center connection to be able to reference the processor in the station's trigger, though you could also use a static reference by using the sampling tool.
Thank you very much for you help, but I would like to release one product at a time one box and one cylinder. Now it`s only coming out in a box, how can I release it in any sequence I want ?
Good afternoon Jason, could you show me how to do this, I couldn´t find what you are talking about. I`m still a beginner.
processador-com-estação-1 (2).fsm
16 People are following this question.
