i want to change the color of the value, "B%" in the image, when the value goes below a set value. Is it possible to do this?
example : it will change to green when the value is >50% and red when the value is <50%
Here is an example model of changing text color based on value:
ModelDocColorDemo_22.0.fsm (FlexSim 22.0)
I used the code button beneath the text editor to edit the html directly. That makes it easier (in my opinion) to insert flexscript in the correct places.
6 People are following this question.
