Mauricio Mb avatar image
Mauricio Mb asked Clair A edited
Error while running program using an Excel spreadsheet
Hi everyone!
I am getting a constant error while running a program. It is a model simulation of a health system, however I am not able to run it appropiately.
The message says:
time: 10.000000 exception: Exception caught in start() of activity Create and Set-up Patients/Create Patient in process flow "Arrivals". Continuing throw...
time: 10.000000 exception: Exception caught in Executive::processeventinlist().
If anyone has been through this or has the solution, please help me :)
FlexSim 22.2.2
exception errorpatient arrivalscreate and setup
· 2
Clair A avatar image Clair A commented ·
Hi Mauricio,
Could you please post your model ?
If you don't want to share it publicly, you can send your model to our French tech support email address: support@flexsim.fr.
Mauricio Mb avatar image Mauricio Mb commented ·
Hi Clair, sorry for the delay
I will send the model directly to the given email adress
Thank you for the response!
1 Like"
Clair A answered Clair A edited
Hi, Mauricio sent us his model and we solved his exception. I share with the community a sample model 2022-10-31 Create patient exception copy labels.fsm to show what triggered his exception.
In this model, I have added a number label Cost in the person labels:
In the Arrivals Process Flow, I create a label on the token with a text value "$1500":
By default, Copy Token Labels is checked in the Create Patient activity:
When you run the model, a patient is created with a Cost number label and the Copy Token Labels feature tries to copy the token's Cost string label to the patient's Cost number label. This triggers the exception below:
time: 0.000000 exception: Exception caught in start() of activity "Create Patient" in process flow "Arrivals". Continuing throw...
time: 0.000000 exception: Exception caught in start() of activity "Source" in process flow "Arrivals". Continuing throw...
time: 0.000000 exception: Exception caught in Executive::processeventinlist().
When you copy labels from a token to a patient, you need to be carefull that if a label already exists on the patient with the same name, it also stores the same data type.
