Devdatta D avatar image
Devdatta D asked ROBIN commented
Add on resource available trigger using code
I am creating transporter object using code in the OnModelReset trigger. I would like to add logic for On Resource Available trigger when I create transporters. how to add the trigger using code?
FlexSim 22.1.1
flexscripttriggerstransporters
Matthew Gillespie avatar image
1 Like"
Matthew Gillespie answered ROBIN commented
You can use the Object.setProperty() method. For example, this code snippet will give the transporter an OnReset trigger that sets its color to red and an OnResourceAvailable trigger that sets its color to blue:
Object obj = Model.find("Transporter1");
obj.setProperty("Triggers.OnReset", "Dispatcher current = ownerobject(c); current.color = Color.red;");
obj.setProperty("Triggers.OnResourceAvailable", "Dispatcher current = ownerobject(c); current.color = Color.blue;");
ROBIN avatar image ROBIN commented ·
Is this the way to set triggers using only code ?
Thank you in advance!
