Tomi Kosunen avatar image
Tomi Kosunen asked Tomi Kosunen commented
Mandatory path and bridge
Is there a way to utilize bridge while operator is moving on a mandatory path? It seems that it doesn't work by default. Pls see the example
mandatory_and_bridge.fsm
FlexSim 22.1.0
astarmandatory pathbridge
Jonah K avatar image
Jonah K answered Tomi Kosunen commented
I was able to get the man to follow the bridge path by slightly adjusting the path locations and making sure the nodes were touching the paths. See the attached model:
mandatory-and-bridge_JK.fsm
Tomi Kosunen avatar image Tomi Kosunen commented ·
Thanks. I also tried to move the spots but apparently I wasn't as precise as you were. It is good to see that it's working although it could permit more tolerance to the location.
