Liam Chiu avatar image
Liam Chiu asked Jason Lightfoot edited
How to set up downtime for maintenance?
Hello
I'm trying to set up downtime for maintenance, when 5 defective products are detected continuously, cutting machine shutdown for maintenance. (Five consecutive defective products can include length, outer diameter and width) I don't know how to set it. I have attached a model of what I have.
Thank you in advance. :)
FlexSim 20.1.3
maintenancepartsdefectiveshutdown
Jason Lightfoot avatar image
1 Like"
Jason Lightfoot answered Jason Lightfoot edited
You first define somewhere the limits for acceptance on each of the characteristics (length, diameter, width)
When the item is finished increment a label if the item is outside of the limits.
When the label reaches 5, stop the machine for a period and reset the count to zero.
When you have this in your model and have removed the exceptions post again if you're having any trouble with implementing that logic.
· 2
Liam Chiu avatar image Liam Chiu commented ·
Hi @Jason Lightfoot
I had set limits and labels, but I don't know how to make the rule when defects appear continuity. Your suggested way is to accumulate the defects.
Thanks for your comments :)
Jason Lightfoot avatar image Jason Lightfoot ♦♦ Liam Chiu commented ·
