Marc R5 avatar image
Marc R5 asked José Antonio MD edited
Use parameter to decide when to import from excel
I am dealing with a model, meanwhile we are creating a custom db to import the data.
To make tests I use also an excel model to import data.
For the db import, I create a parameter and a custom code so I can decide if I import from the db or not, with a simple conditional.
Is something similar for the excel import?
I see that in the excel import/export menu there is a post import code option, but I would like to be able to do it in custom codes and using parameter, specially for the import decision.
Thanks!
FlexSim 22.1.1
excel importcustom codeparameters
José Antonio MD avatar image
José Antonio MD answered José Antonio MD edited
Hello @Marc R5,
You can use a parameter condition (f.ex.: if....else...) and if the condition is tue,use the following code to import excel files:
excelmultitableimport()
I hope I have been helpful.
