Yokota T avatar image
2 Likes"
Yokota T asked Ryan Clark commented
Export global table with symbol-characters to database
Hi all,
I'm trying to export my global table to the database(MySQL). But the exporting fails.
My guess is that because the column name has symbol-characters. I experimented on exporting. When I used ',' or '(', it failed. But when I used '$' or '_', it succeeded.
What characters can I use in the column name?
Thanks.
FlexSim 21.0.6
databaseexport dataexportdata export
· 3
John-Michael avatar image John-Michael commented ·
Thank you for your question!
To help us in providing a clearer answer, could you send us a copy of your model?
Yokota T avatar image Yokota T John-Michael commented ·
Here is my model.
Export_to_MySQL.fsm
In GlobalTable1, I can export only "Time" column.
In GlobalTable2, I can export only "$" column.
export-to-mysql.fsm (98.8 KiB)
Ryan Clark avatar image Ryan Clark commented ·
Hi @Yokota T, was Jordan Johnson's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
Jordan Johnson avatar image
Jordan Johnson answered
In the database export tool, try wrapping your flexsim column names in square brackets:
To export to the database, we currently run a query in FlexSim to create the table that will be exported. Basically, this tool writes the following code:
Table toExport = Table.query("SELECT [#], [!], [)] FROM GlobalTable2");
// Then we iterate through the rows of toExport, sending them to the target table
So the "From FlexSim Column" values may need to be wrapped in [].
