Jose Sousa avatar image
Jose Sousa asked
How to create my own variables to pass as parameters to a defined function?
I have a .dll that I made to read data from flexsim and send it to a sqlite database while a simulation is running. This is the function that i call in a flexsim trigger:
__declspec(dllexport) int InsertDb(int runNumber, double time, const char* dataKey, const char* dataValue) {
    sqlite3* db;
    char* errMsg = 0;
    char sql[1000];
    int rc = sqlite3_open("path/to/database.db", &db);
    if (rc != SQLITE_OK) {
        fprintf(stderr, "Can't open database: %s\n", sqlite3_errmsg(db));
        return rc;
    snprintf(sql, sizeof(sql),
        "INSERT INTO SimulationData (RunNumber, Time, DataKey, DataValue) VALUES (%d, %f, '%s', '%s');",
        runNumber, time, dataKey, dataValue);
    rc = sqlite3_exec(db, sql, NULL, NULL, &errMsg);
        fprintf(stderr, "SQL error: %s\n", errMsg);
        sqlite3_free(errMsg);
    sqlite3_close(db);
    return rc;
When i run the simulation everything works, but, as you can imagine, the records inside the database are all empty. Thats because im struggling to find a way to fill these parameters:
  • RunNumber
    • The number of the simulation running
  • Time
    • Timestamp of when the simulation started
  • DataKey
    • The name of the current component where the box is
  • DataValue
    • The trigger event thats happening (like a short description, eg. "Item entered on Processor")
I want to fill those values dinamically but i cant find a way to make it.
FlexSim 25.0.2
databaseexport datavariablesflexsim25dll c
