Claire Krupp avatar image
Claire Krupp asked Joerg Vogel commented
Using AStar to model Tuggers w Dollies
I am modeling a system with multiple tuggers that each pull up to 3 dollies around the plant. I need to use AStar because my customer requires a heat map of congested areas.
How do I show the tuggers pulling the dollies? I have done it before using an AGV network, but none of that logic seems to work with AStar.
The only way I can think of is to load the dollies into the tugger and then just manipulate the location and rotation of the dolly using "Change Visual" PF blocks, but then the dollies are "stiff" when going round corners.
Does anyone know a way to use the "Attach Trailer" logic in AStar?
Thanks!
FlexSim 21.2.4
astar navigatorattach trailertuggers
Ryan Clark avatar image
Ryan Clark answered Joerg Vogel commented
Hi @Claire Krupp,
Unfortunately, there is no direct way to use the attachtrailer() command while using the A* Navigator. As you can see on FlexScript Class - AGV (flexsim.com), the AGV class can only reference, "A TaskExecuter that is connected to the AGV network as an AGV Traveler."
And attachtrailer() is a command that only works for the AGV class. There is also currently no way to use two navigators at the same time, so the task executer cannot be connected to both networks. You can see the example models that I made below:
agv-trailer-test-rc.fsm (AGV Network)
agv-trailer-test-astar-rc.fsm (A* Navigator)
As you can see after running the second model, the Attach Trailer code throws an error since the TaskExecuter is not attached as an AGV traveler to a network.
Alternatively, you could try using the AGV Network along with a different method of creating a heat map. See the links below for possible solutions:
How to show the heat map by myself? - FlexSim Community
Heat Map Feature For Network Node and AGV Navigator - FlexSim Community
Sample Model Tracking Social Distancing Metrics - FlexSim Community
I hope this helps! Please let us know if you have further questions!
· 4
Claire Krupp avatar image Claire Krupp commented ·
Hi @Ryan Clark , thanks for your comprehensive answer. I will look into creating a heat map on an AGV network for future projects.
Ryan Clark avatar image Ryan Clark Claire Krupp commented ·
You're welcome! Glad to help!
Borja Lorenzo avatar image Borja Lorenzo commented ·
Is the visual functionality of representing the AGV load as a train still only available for the AGV network method? If so, is there still no possibility of synchronizing both systems (AGV network and AStar)?
Thank you in advance for your comments.
Joerg Vogel avatar image Joerg Vogel Borja Lorenzo commented ·
@Borja Lorenzo, it is a Flexscript API class. You can look yourself if you find any method that acts as you want to behave. It is not common to control a Taskexecuter by more than one navigator.
