Hi everyone,
I encountered a problem in my model that happen during unloading an item from queue using a task executer.How do i fix this?
Hi everyone,
@Andre T6 Your involved 2 is NULL. This should be the station you unload to. So you have to look in the code or the process flow where you create the tasksequence and check the reference to the station where you want to unload to.
If you want more assistance you should upload your model.
Hi @Steven Hamoen
QueueModel.fsm
Here is the model
The names of the cluster queues are different than what you typed in the custom code that assigns the destination to items from Queue1. The queues have a space between "Cluster" and their number. This is missing in the "find"-commands. As a result the destination isn't correctly assigned, because the objects can't be found.
19 People are following this question.
