Phil BoBo avatar image
8 Likes"
Phil BoBo posted Wang Yang commented
FlexSim 2019 Beta Available
FlexSim 2019 Beta is available. (Updated 21 December 2018)
Release Notes
  • Added support for importing JT files.
  • Added a way to directly animate 3D shapes with bones.
  • Added a way to parent subcomponents to a bone on a 3D shape.
  • Updated calculated tables and chart templates to be able to save their data during an experiment.
  • Added support for SQL keywords UNION, UNION ALL, INTERSECT, and EXCEPT.
  • Updated the time table's weekly and daily modes to use a graphical display.
  • Improved the time table's user interface.
  • Added options for stacking bars on a histogram and added more bar modes.
  • Added a Column Sets feature to statistics collectors.
  • Added more options for event listening in statistics collectors.
  • Added an option to statistics collectors and calculated tables for object path display depth.
  • Added an option to statistics collectors to stop tracking row values after specified events.
  • Added an option to milestone collectors to start new entries on the next milestone.
  • Added options to record more data in additional columns on a milestone collector.
  • Added enable/disable right-click menu options to statistics collectors in the toolbox.
  • Improved the performance of calculated tables in certain configurations.
  • Fixed a bug with Always Leave Entries on List when reevaluating multiple back orders.
  • Fixed a bug with color spilling from one mesh to another when using shape data overrides.
  • Fixed scaling issues and a crashing bug when loading certain STEP and IGES files.
Process Flow
  • Improved the Token.create() method to be able to create child tokens.
  • Added a new Person Flow type of Process Flow.
  • Fixed a bug with a resource connected to a global list deleting the list when the resource was in an instanced flow.
People
  • Added a Process activity.
  • Added a Remove Person activity.
  • Added various activity sets to quickly create common groups of activities.
  • Added a priority value to resource objects that is used for acquiring and preempting resources.
  • Added advanced options to the Process activity for handling preemption.
  • Added functionality for simulating shift schedules with time tables and down behaviors.
  • Improved the UI for how people objects are added to groups.
AGV
  • Improved control point selection on paths in the 3D view.
A*
  • Added a way to draw a heat map based on a node's percentage of total traversals.
  • Added a Two Way option to preferred paths and dividers.
  • Added a Condition option to A* objects to optionally disable them under certain circumstances.
  • Added a Mandatory Path object used for defining sets of paths where certain connected objects can travel.
  • Updated the Barrier object to be able to specify patterns to determine how it affects the grid.
  • Added a FlexScript API for A* objects and data.
  • Fixed a bug with A* barriers blocking space larger than their actual size.
product announcementbeta
· 9
Phil BoBo avatar image Phil BoBo ♦♦ commented ·
The JT importer has a known issue that it does not currently scale the object correctly based on the units specified in the file. The file will come into FlexSim in whatever units your model is in regardless of the units specified within the file.
This issue should be fixed in an upcoming release of the library we are using to load the JT files.
In the meantime, you can re-scale your JT shapes using the unit conversion popup on the General tab of an object's Properties window:
1. Click in each size field and then press the Model Unit Conversion button:
2. Select the model units that the shape was built in and then press the Convert button:
The "Escort Patient to Exit" activity set throws an exception when you try to create it.
This bug has been fixed in the 15-Nov beta.
Michael Machado avatar image Michael Machado commented ·
Please, see the image below. I found it when I was testing the v2019 Beta.people-module-11-activity-set.fsm
People Based Model Tutorial
TASK 1.1 - USE AN ACTIVITY SET
Matthew Gillespie avatar image Matthew Gillespie ♦♦ Michael Machado commented ·
The tutorial is still a little behind the last changes to the software. Instead of creating a general flow and an instanced flow, you should instead create a Person Flow. Selecting this option will create the general Arrivals flow with a Create Person activity and link it to the new Person Flow. The drop down and sampler of the People Flow field let you sample Person flows, but not TE Instanced flows anymore.
@phil.bobo The material you said is still 2019.0.0 beta of Nov 9 not of Nov 30.
Would you make it updated?
Phil BoBo avatar image Phil BoBo ♦♦ David Seo commented ·
I don't understand your question.
David Seo avatar image David Seo Phil BoBo ♦♦ commented ·
You wrote it above as Updated 30 Novemeber but it is still 9 Nov like followed;
Kyle Y avatar image Kyle Y commented ·
Hi Phil, thanks for your information. I have tried to find the version 2019 in the mentioned link but failed. Could you please post a download link for version 2019? Thank you.
Wang Yang avatar image Wang Yang Kyle Y commented ·
You can contact me.(wangyang@csn-bj.com);I will send you the download link.
phil.bobo contributed to this article
