Phil BoBo avatar image
6 Likes"
Phil BoBo posted
FlexSim 2018 Available
FlexSim 2018 is available.
Release Notes
  • Added a new People module. (Try out the Sample Models.)
  • Added new dashboard chart templates to quickly collect and display statistics.
  • Legacy charts are hidden by default in the Library and can be enabled through Global Preferences.
  • Removed the basic Person flowitem and renamed the TaskExecuterFlowItem to Person.
  • Added functionality to the List's pull method to allow you to pull an object/node directly (without writing SQL).
  • Updated ODA to be compatible with DWG 2018 shapes.
  • Updated Assimp to be compatible with the latest FBX file format.
  • Added a RegExResult class for iterating over the matches in a regular expression.
  • Lists can now use arrays as partition ids.
  • Added a mechanism for automatically setting the reset position of objects after moving them by setting their resetposition variable to 1.
  • Added a By Lazy Interval update mode to the calculated table.
  • Improved calculated table performance by reducing the amount of table updates.
  • Improved statistics collector performance by reducing the number of updates to Always columns.
  • Table views can now be set as read-only using the grayed attribute.
  • Added an Ignore Warmup option to statistics collectors.
  • Updated OptQuest so that it can run more than 10,000 solutions.
  • Added a pick option for restoring default values in the Global Table's On Reset trigger.
  • The Query test field is now a multi-line text box.
  • The Source now adds labels to items before calling the OnCreation trigger.
  • Updated the table selection for the Excel Import/Export.
  • Improved color options in various dashboard charts.
  • Changed the model update dialog to be able to autosave the model with an incremented number.
  • Added many new animations for the operator and the person flowitem.
  • Updated many stochastic pick options to use getstream() as the default stream parameter.
  • Updated the TaskExecuter to connect to the DefaultNavigator when created.
  • Improved the Group UI.
  • Updated the Library view to not change when clicking on the User Manual view.
  • Changed the Tree view's Explore > As Code so that it closes the tree's edit view.
  • Fixed a bug with list initial contents having old values in label fields.
  • Fixed a bug with the statistics collector chart interface checkboxes.
  • Fixed an OnDropWindow exception.
  • Fixed some exceptions in the Table View when viewing an Array that no longer exists.
Process Flow
  • Added a Date Time Source activity.
  • Added a Wait for Simultaneous Arrivals Before Entry option to the Zone.
  • Added autocomplete for instanced flow labels (current).
  • Added a zoneistokeninsubset() command.
Conveyor
  • Added a Round Robin destination option to the Send Item pick option.
AStar
  • Added a visual option to show the travel threshold for objects.
  • Improved the draw performance and fixed the timing of some graphical updates.
AGV
  • Fixed a bug with redirecting AGVs at times other than On Pre-Arrival of way points.
product announcement
phil.bobo contributed to this article
