Update: FloWorks 17.2.1 has been released on September 18.
FloWorks 17.2.0 for FlexSim 2017 Update 2 has been released. This new version of FloWorks has some major changes to align it with recent updates to FlexSim, such as dot syntax, Process Flow templates, and a revised user manual.
The bug fixes in this version are also available for FlexSim 2017 Update 1 as FloWorks version 17.1.3 and for FlexSim 2017 (LTS) as FloWorks version 17.0.6.
FloWorks downloads can be found in the Downloads section of your FlexSim account on the 3rd party modules tab.
Please do not hesitate to report any bugs, usability improvements and feature requests to support@talumis.com.
About FloWorks
Release notes
FloWorks 17.2.1
- Bug fix: Adding charts using "Pin" buttons would show error message.
- Bug fix: Incorrect reference in Wait For Event activity in Mixer recipe schedule template for Process Flow; disabled Repeat Schedule by default.
- Bug fix: FloWorks objects remove pending events from the list when they are destroyed.
FloWorks 17.2.0 (September 1, 2017)
For FlexSim version 17.1.x use FloWorks 17.1.3.
For FlexSim version 17.0.x (LTS) use FloWorks 17.0.6.
- Added
FlowObject
class interface ("dot syntax") for majority of FloWorks objects. - Can now access products by name when using FloWorks product table
( e.g.source.product = "Raw material"
instead ofsource.product = 3
). - Can define recipes for products in the products table and dynamically load / execute them on Flow Mixers.
- Added Process Flow templates for mixers executing production schedule and flow tank with cleaning / certification.
- Updated Pin to Dashboard buttons to use Statistics Collectors to collect data.
- Revised most of the user manual (tutorials are missing, will be re-released in a future version).
- Bug fix: Calling
SelectFlowIp
andSelectFlowOp
with multiple ports produced FlexSim error. - Bug fix: When using a product table, sometimes the Product dropdown would not show the correct product when opening Properties.
- Bug fix: Flow Conveyor would not suspend correctly when output flow restricted.
FloWorks 17.1.3
For FlexSim version 17.2.x use FloWorks 17.2.0.
- Bug fix: Calling
SelectFlowIp
andSelectFlowOp
- Bug fix: Flow Conveyor and Mass Flow Conveyor can cause FlexSim to crash, when used in combination with a product table.
FloWorks 17.0.6
For FlexSim version 17.1.x (LTS) use FloWorks 17.1.3.
- Bug fix: Calling
SelectFlowIp
andSelectFlowOp
