FloWorks 22.1.0 is now available (12 May 2022). This version of FloWorks is intended for use with FlexSim 2022 Update 1.
If you are using FloWorks with FlexSim 2022 (LTS) please use FloWorks version 22.0.1.
All versions can be found in the Downloads section of your FlexSim account on the 3rd party modules tab. Please do not hesitate to report any bugs, usability improvements and feature requests to support@talumis.com.
About FloWorks
Release notes
FloWorks 22.1.0
- All bug fixes in FloWorks 22.0.1 below.
FloWorks 22.0.1
- Added support for Object Property Tables
- Bug fix: incorrect MassFlowConveyor content
- Bug fix: LoadingPoint issue with not-released positions (and status)
- Bug fix: Object created at incorrect scale when not using meters
The documentation at docs.flexsim.com is in progress of being updated with the new release and will become available shortly. Until such time you can use the offline documentation included in the FloWorks installer and available through the Help menu in FlexSim.
