Jiayi L avatar image
Jiayi L asked Joerg Vogel answered
How to get the output value of a source
I have a source connected with 4 queues. The way to send to port is First available. I want to get the output value of the source for each item and reuse it for the label Place.
This is what I've written in Assign Labels :
int output = Model.find("Source1").as(Object).stats.output.value;
Object Place = Model.find("Source1").as(Object).centerObjects[output];
return Place;
But it shows an error : Array index out of bounds
Can someone helps me to correct it or is there another way to do it?
FlexSim 19.0.0
flexsim 19.0.0assign labelscostum code
Jiayi L avatar image Jiayi L commented ·
I mean I want to get output ports number for each item
Joerg Vogel avatar image
1 Like"
There is an OnExit trigger of the source. You can use the Data Property “Set Label”
  • Object is item
  • Name is Place
  • Value is port
port is a source code declared variable evaluating the output port the item went out.
Bo.W avatar image
Bo.W answered CSN commented
Of course, if you output to more than 4, you don't have so much output ports or center ports.
Newers are advised to contact local suppliers for more basic help @CSN ,Or you can refer to the user manual case.
CSN avatar image CSN commented ·
@Jiayi L The latest version v2021.1 is recommended. In order to solve your problem better and faster, you can contact our local China partner (BJCSN), We will provide you with professional FlexSim technical Q&A. contact information: support@csn-bj.com; QQ:1093796825
