Li X avatar image
Li X asked Jeanette F commented
Turn each item on the tray blue
when i use setlcolor( obj object, num red, num green, num blue ) it works;
But when I use Color ,it cannot work;
the following is the error tips;
FlexSim 19.0.0
flexsim 19.0.0change color
· 2
Hi @Li X, was Phill BoBo's answer helpful? If so, please click the red "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
CSN avatar image CSN commented ·
First,you can use the method of BoBo to test your question. If you haven't solved,you can contact our local China partner (BJCSN), We will provide you with professional FlexSim technical Q&A. contact information: support@csn-bj.com;
In order to solve your problem better and faster,please upload your model file.
-1 Like -1 ·
Phil BoBo avatar image
1 Like"
Phil BoBo answered Phil BoBo edited
subnodes[index] returns a treenode.
The color property is a property on an Object.
You need to cast the treenode as an Object.
For example:
Object obj = object.first.subnodes[index];
obj.color = Color.blue;
or
object.first.subnodes[index].as(Object).color = Color.blue;
