dear all,I want to use felxsim to call the dll,but I can only download module sdk 20.2 in flexsim download page
If you have maintenance contract you would have a button which allows you to load more versions.
In such cases where I can not see a direct link to a suitable download file I assume the path to an available download object is similar built for previous versions. I try to adjust the address path. Maybe I am lucky.
We recommend that you use the new version of FlexSim and SDK files for testing.
In order to solve your problem better and faster, you can contact our local China partner (BJCSN), We will provide you with professional FlexSim technical Q&A. contact information: support@csn-bj.com; QQ:1093796825
14 People are following this question.
