Wuthering H avatar image
Wuthering H asked CSN commented
how to pull the item in batch according item's label from disoder item list
I have a problem : I have generate the box(item) demand for every parts according assembly line consumption(c/t=150s,finished product has 71 parts),and i add some label on item (partsno,boxcapacity, boxsPerPallet , pointofuse,deliveryroute...) . then i want to package the box to a delivery pallet;so i push box-item to list.but because the item flow is disorder.
i have trouble :when any part's box quantity reach to its boxPerPallet number in list,how to pull out by packageStation(combiner) ,and the first part box accumulate to pallet will be palletlize first,then the second part....
i attached an example,tks for help.
assembly_pick oder_simulation_V1.fsm
FlexSim 19.0.0
flexsim 19.0.0pull from list
CSN avatar image CSN commented ·
In order to solve your problem better and faster, you can contact our local China partner (BJCSN), We will provide you with professional FlexSim technical Q&A. contact information: support@csn-bj.com; QQ:1093796825
