265.196 avatar image
265.196 asked Jeanette F commented
AGV can't load special items
TASK 4.4 - CUSTOM AGV SETTINGS
AGV can't load waste or dirtylaundry from high floor when I am learning task 4.4 custom AGV settings of user manual.I don't know where the problem is.I will attach the model, so please check it. 2020-09-29-13-37-58.giftask4.4.fsm
FlexSim 19.0.0
flexsim 19.0.0agv load
task44.fsm (207.6 KiB)
· 3
PeterHe avatar image PeterHe commented ·
I have the same problem as you.
Jeanette F avatar image Jeanette F ♦♦ PeterHe commented ·
Hello @PeterHe, This is an issue that is fixed in a bug fix release of 19.0. If you open a newer version of FlexSim then it will go away.
CSN avatar image
CSN answered CSN edited
@265.196 task44_2020.2.fsm
It is ok to open it in version 20.2, it is recommended to use version 20.2.
In order to solve your problem better and faster, you can contact our local China partner (BJCSN), We will provide you with professional FlexSim technical Q&A. contact information: support@csn-bj.com; QQ:1093796825
task44-20202.fsm (211.9 KiB)
