Fu P avatar image
Fu P asked Fu P commented
Web Server Problem
When I try to set up WebServer, the following error occurr:
I copied the FlexSim installation folder into the WebServer folder. The webServer configuration file details are as follows:
Flexsim Program Directory: C:\Program Files (x86)\FlexSim Web Server\FlexSim 2019 Update 2\program
Model Directory: C:\Users\dell\Documents\FlexSim 2019 Projects
Flexsim Data Directory: C:\ProgramData\Flexsim\FlexSim19.2
Model Uploading: no
Model Downloading: no
Model Deleting: no
Max Upload Size (bytes): 10000000
Reply Timeout (milliseconds): 10000
Max Instances (of Flexsim): 8
Max Threads Per Instance: max
Max Job Queue Length: 100
Max Job Timeout (seconds): 3600
Port:10.133.244.33:80
Ignore Auto Save Files: yes
Use Windows Authentication: no
Restrict UserGroup Directories: no
Active Directory:
url: ldap://dc.domainName.com
baseDN: dc=domainName,dc=com
username: specialUser@domainName.com
password: password
FlexSim 19.2.4
flexsim 19.2.4webserver
· 4
Fu P avatar image Fu P commented ·
do I have to fill these information?or just let it default ?Thanks in advance
Active Directory:
password: password
Are the username&password same as my account and password for logging into this website?
@Ben Wilson I read your other answers, but they don't seem to apply to my current question
@wang.yang
can anyone help me with this(╯﹏╰)
Wang Yang avatar image
Wang Yang answered
Thanks for your help~Yesterday, our engineers advised users to install V2018.2 software, and the problem has been solved; We really haven't noticed the problem of installation path you mentioned.
Braydn T avatar image
2 Likes"
Braydn T answered Fu P commented
@Fu P
If your active directory needs special permissions to access, then you can configure the active directory fields.
It looks like you have an IP address in the field for port. You should have just a port there, like 80.
· 5
Thank you for your reply.
I'm using FlexSim for a LAN connection to a Server which installed FlexNet Publisher License Server Manager .
This is my flexsim License Activation:
I don't know if that's the reason why I can't set up webserver correctly
Braydn T avatar image Braydn T Fu P commented ·
@Fu P
If all the directories in your config file are valid, the webserver will start up, you just wont be able to start flexsim. Did you try changing the port field to 80? If so, did you still get an error? Was it the same error?
The FlexSim Webserver is separate from the license server, just to be clear.
Fu P avatar image Fu P Braydn T commented ·
Sorry for the late reply. I have tried to set the port to 80 without IP, but the same error still exists .I tried other numbers,with or without IP, but it still didn't work
Ben Wilson avatar image
1 Like"
Ben Wilson answered Fu P commented
Hi @Fu P,
I would start with the default flexsim webserver configuration.txt and only change the minimum directives to get it working.
Also, make sure there are no other servers running on your PC, or change the port number to an unused port.
On your question you marked your FlexSim version as 19.2.4. Be sure to use the FlexSim Webserver 2018 version 18.2.0:
· 2
Ben Wilson avatar image Ben Wilson ♦♦ commented ·
In your question you posted your config text and had the following:
This would be very unusual for FlexSim Simulation Software to be installed under the FlexSim Web Server. The most likely location for your FlexSim 2019 install would make this line:
Flexsim Program Directory: C:\Program Files\FlexSim 2019 Update 2\program
or depending on your system, you may be able to keep the shortcut path:
Flexsim Program Directory: %PROGRAMFILES%\FlexSim 2019 Update 2\program
Fu P avatar image Fu P Ben Wilson ♦♦ commented ·
thanks for your help,I keep to the shortcut path and solved the problem.
