I have buckets and I need them to be stacked one inside the other as shown in the figure. Is there a possibility of doing this?
@richard P3 You can use the setlocation command in an on entry trigger. You will have to get the location of the last object, most likely using the subnodes command. Once you have the location of the last object, you can increment some of its attributes by the desired amount, and it will appear to be stacked. Here is the reference to these commands in the user manual: User Manual
The commands are under Object Spatial Attributes.
13 People are following this question.
