Pinakin K avatar image
Pinakin K asked Felix Möhlmann commented
Dashboard does not update the AGV battery recharged level.
agv-battery-recharge.fsm
In the attached model it can be seen that the agv goes into charging, and when it has completed the charging it starts travelling. But when the agv completed its charging, the battery level is not updated on the dashboard.
the recharge level it should have shown is 80 but it only updated when the level dropped from 80 to whatever the level was at that time. Is there an explanation for this?
PS the plot updates when the battery level changes.
FlexSim 20.0.2
agv battery level
Jordan Johnson avatar image
Jordan Johnson answered Felix Möhlmann commented
When you listen to a Kinetic Tracked Variable, you need to be sure the update mode is set to Update, rather than OnChange. For things that change at set times, like Content or Input, OnChange works great. However, OnChange doesn't include when the rate changes. Update does.
· 3
Pinakin K avatar image Pinakin K commented ·
Yeah. makes sense. Thanks It works
CHRISTIAN B3 avatar image CHRISTIAN B3 commented ·
Which "update mode" you are referring to and where can I find it. I also need to change it to Update, but couldn't find it.
Felix Möhlmann avatar image Felix Möhlmann CHRISTIAN B3 commented ·
In the Event Listening tab of the Statistics Collector.
