I can't seem to get any graph showing with the Throughput per hour or Composite Throughput per hour templates. The graph axis change with time but there is no graph showing.
See attached model.problem-with-throughput-template.fsm
The time plots, unlike the table and bar charts, show the throughput at each hour, rather than total throughput / total hours. If you run the model for several hours, you can see the hour-by-hour trend in throughput:
8 People are following this question.
