Mike Mayer avatar image
1 Like"
Mike Mayer asked Jeff Nordgren converted comment to answer
What is the dot syntax for getting the "max content" of a queue?
I scoured FlexSim Class Reference and could not find it, nor in any dot-leaf autofill. Related to this, is there a full canonical listing of all branches and end-leaves of the entire dot syntax structure? For example, Help > User Manual > Contents > Reference > Coding in FlexSim > FlexScript Class Reference > Object > attrs stops short of the rest of the tree beyond (i.e., document what comes after .attrs). All it shows is an example, what I need are all the tree leaves that are subnodes of .attrs. for example. Thanks.
FlexSim 18.0.7
dot syntax max content
Mike Mayer avatar image Mike Mayer commented ·
Thank you both Tanner and Jason.
I wound up using both code fragments, one to get the static maximum content, and the other to compare to see how close we are getting to "full".
Mike
Jason Lightfoot avatar image
3 Likes"
Jason Lightfoot answered
And if you wanted the statistic dot notation here's an example:
Object q= model().find("MyQueue");
return q.stats.content.maximum;
tannerp avatar image
tannerp answered Jeff Nordgren converted comment to answer
You can try using the following code:
getvarnum(Model.find("MyQueue"), "maxcontent");
tannerp avatar image tannerp commented ·
Additionally, the "Commands" list is helpful in learning FlexScript.
