K_yun avatar image
K_yun asked Jeff Nordgren converted comment to answer
How to coordinate the inputs or outputs of separator/combiner?
20181107.fsm
As shown in the model i've attached, i need the Mergesort stop receiving flowitems when the separator is working ,but something wrong seems happen to the trigger setting ,so i post this question and look for an ideal solution.
FlexSim 7.7.4
outputinputtemergesort
20181107.fsm (21.2 KiB)
· 3
K_yun avatar image K_yun commented ·
I found a way to implement the model by setting the trigger founction of the Sink below the separator, now the Mergesort will stop receiving flowitems when the separator is working. But here appears another problem which is shown in the following GIF002.gif
Sebastian Hemmann avatar image Sebastian Hemmann K_yun commented ·
Could you maybe explain more exactly what is the problem and what is going wrong where?
K_yun avatar image K_yun Sebastian Hemmann commented ·
Ok hemmann. The flowitems flow through the mergesort have three itemtypes(1、2、3), and the type1 will be sorted at the first outputport of the mergsort while the other two types keep going through the outputport2. As you can see, the type1 will get processed at the separator after sorted, here i want the mergesort still receive type2 and type3 but not type1. When the separator finish the process, the mergesort becomes availiable to all the three types again. I hope now you get what i mean and look forward to your reply, thank you.
Jeff Nordgren avatar image
Jeff Nordgren answered
@meng L,
It appears that the FlexSim license that you are using has expired. You should contact your local distributor for help with you model. Here is their contact information:
Beijing Chuangshineng Technology Development Co.,LTD
A202Rm Zhong Guan Cun Fazhan Tower
12 Shang Di Information Road
Haidian District, Beijing 100085
People Republic of China
phone: [86]108-278-0244
mobile: [86]137-184-49711
zhouxy@csn-bj.com
www.csn-bj.com
· 3
My license seems have no time limitation after contacting your distributor CSN, and my license information shows the Expiration Date is permanent.
Jeff Nordgren avatar image Jeff Nordgren K_yun commented ·
@meng L,
Yes, your license is permanent. Meaning that you can use your license forever. However, the maintenance agreement for support that originally comes with the software does have an expiration date. Meaning that after that expiration date, customer support from FlexSim is no longer free. You can post here to see if other users can help you but your software is almost 3 years old. Not sure how many users use that version any more. That is why I suggested that you contact your local distributor for technical support for your model. They can help you and/or get you upgraded to the current version of FlexSim.
K_yun avatar image K_yun Jeff Nordgren commented ·
Thanks for your sincere explanation and suggestion, we have taken the upgrade affair into consideration.
