Antonio L avatar image
Antonio L asked Abraham Vo2 commented
FlexScript exception - Label does not exist.
Hi All,
this is my first review of FlexSim and my first model. I'm trying to model a system where two sources create two different parts. One part will be processed in a first Processor and the other to a second processor. If I include a "conditional port" or a "Port by case" in the output of the Queue between the sources and the processes I get this message in the system console everytime a part is processed:
time: 18.000000 exception: FlexScript exception: Label property Type retrieved on /Queue1/Box. Label does not exist. at MODEL:/Queue1>variables/sendtoport
Also, the system is not working as expected. What am I doing wrong?
Thank you.
FlexSim 18.2.0
exceptionconditional portport by case
Roi Sánchez avatar image Roi Sánchez commented ·
Hello @Antonio L, would it be possible that you attach the model? Then, it could be seen what it is happening and help you.
gilbert jerald avatar image
gilbert jerald answered Abraham Vo2 commented
@Antonio L
Hi Antonio,
Port by case logic will work on the basis of label-value on the created item. The error that you get is because you didn't set a label value on the created item.
I have attached the model for your reference have a look at it.
support-1.fsm
support-1.fsm (266.2 KiB)
· 3
Antonio L avatar image Antonio L commented ·
Thank you gilbert jerald. That was the key.
The model you sent was very helpful.
Regards.
Abraham Vo2 avatar image Abraham Vo2 commented ·
Hola que tal amigo @gilbert jerald . Un favor . Me podrías ayudar en una simulación parecida al error que le salió al amigo @Roi Sánchez
Abraham Vo2 avatar image Abraham Vo2 Abraham Vo2 commented ·
te dejo mi correo bro espero y me puedas ayudar abraham.vazquez1768@uppuebla.edu.mx
