I need to set position of flowitem when enter in coveyor without using decision point.
i need to set in the upper or lower border of conveyor based on type.
try with On Entry trigger but dont affect the position of item.
thanks
thanks
Thank you for uploading your model. I created it using two conveyors and decision points. I attached a new model below. Let me know if this is more like what you want to achieve.
yes, someting like that.
the idea is that one operator enter the flowitem in the side of the conveyor.
thanks
I used two smaller sized conveyors and and dragged them each to the end of the main conveyor. Then I hid the two conveyors so it looks like there is just the main conveyor. Does this make sense?
If you are able to upload your model, I could take a look at it and try to help you incorporate this into your model.
thanks for your answer, that help me.
Finally i can put 2 flowiems in the conveyor with a Merge Controller prueba2.fsm
I'm not sure if I understand correctly. How would you like the merge collector to work in your model?
You have right.
At the begining i had problems with the entrace of flowitmes, when two items enter at the same time, the both stop, in that cases the merge help
thanks for all help
9 People are following this question.
