I have a lot of items with different types from a source but I need to transport them only when I have a pair with exactly the same type. Else, the item have to stay in the queue.
Can you give us some more context or attach a model? Is the queue pushing items to other parts of the model or are things pulling from the queue?
Nice model Jordan! Does a fantastic job of showcasing the power/usefulness of the Batch activity.
Thanks, it's perfect but when I try to do it alone, it doesn't work, can you tell me why ?
Hello Théo,
Your model is almost complete, but some little details are missing if you compare your model with the one of @jordan.johnson.
1. In the first activity, assign a label name to the releasing item:
2. In the batch activity, select Make Array in the Aggregation column:
3. Pick a destination (Queue2) in your second travel activity:
4. The item to load is token.Item not token.Items:
Here is your updated model: 12109-example.fsm
10 People are following this question.
