David Seo avatar image
David Seo asked Matthew Gillespie answered
How can the Barriers of AStarNavigater be drawn on the second floor?
@Jeff Nordgren
I am making a model using the barriers of AstarNavigator both on the ground and second floor.
But I found the barriers not to be drag and drop on the second floor of height 4 of Floor Z. The model has many barriers in the first floor ground and the second floor (exactly mezzani) sbhould independently have many barriers. I tried to drag the barriers on the plane container of height 4 but it failed.
How can I do it?
If it is not possible currently, can I use the network node?
FlexSim 18.0.2
barriers on the second floor
Matthew Gillespie avatar image
2 Likes"
Currently they can't. The only mechanism for accomplishing what you want right now in AStar is to lay the floors out next to each other at the same Z height. You can then put a divider between the two floor so that people can't walk between the floors. Finally, you add a bridge object to connect the two floors together at any point you want stairs/elevators.
Like you suggested, you can also use network nodes, but it's one or the other. You can't have AStar control the first floor and network nodes control the second.
