Mischa Spelt avatar image
Mischa Spelt asked Mischa Spelt commented
Queries not working when accessing labels on labels
Lists and resources seem to have a problem when the pull or acquire query access a label on a label using dot syntax. In the attached model I am creating items in a queue and in the pull action on the top I am trying to find a token for which the token's item has a Product with a particular value. The pull throws an "Invalid SQL Query" error and breaks.
The second option, using the old-fashioned getlabel syntax, does work.
Is this supposed to happen?
FlexSim 17.0.0
labelsbug reportquerylistsdot syntax
Matt Long avatar image
1 Like"
Matt Long answered Mischa Spelt commented
Unfortunately queries are parsed using our SQL parser which is a completely different parser than the compiler uses for FlexScript. We made the SQL parser work with a single label accessor, but adding functionality for multiple label accessors is not trivial. At some point we would like to add this in. We'll add this to the dev list.
· 4
Joerg Vogel avatar image Joerg Vogel commented ·
@Matt Long What happens then in the statement I posted? puller.Product = value.Producte
Matt Long avatar image Matt Long Joerg Vogel commented ·
That works just fine because you're using a single label accessor on puller and value. Where you would run into issues was if you said puller.Product.serial = value.Producte.serial
Joerg Vogel avatar image Joerg Vogel Matt Long commented ·
@Matt Long
Thanks for the answer. Regards Jörg
Mischa Spelt avatar image Mischa Spelt commented ·
Thanks for both the reply, and considering this for a future release. One of the reasons I love the dot notation is because I got a bit tired (and confused) with writing getlabel(getlabel(...)) :-)
Joerg Vogel answered Joerg Vogel edited
@Mischa Spelt
Maybe you should use unique names for your labels. If you do so, then the condition
seems to work.
I added to the label name "Product" simply the letter "e".
Here ist the file.
