Tom H6 avatar image
Tom H6 asked Tom H6 commented
How can I get AGV allocating certain control point
I´m trying to do some customized AGV path planning and a great advantage for my model would be to be able to find which AGV has the first allocation on a given control point. I'm able to get number of allocations on control point and an allocation as treenode, but I'm struggling with getting to AGV that does the allocation.
I would be grateful for any advice.
FlexSim 25.1.1
agvagv pathsallocation
agvpaths.fsm (39.4 KiB)
Felix Möhlmann answered Tom H6 commented
You can get that pretty easily nowadays through the AGV.AllocatableObject class.
https://docs.flexsim.com/en/25.0/Reference/CodingInFlexSim/FlexScriptAPIReference/AGV/AGV.AllocatableObject.html
agvpaths_1.fsm
agvpaths-1.fsm (39.4 KiB)
Tom H6 avatar image Tom H6 commented ·
Thanks for your advice.
I was able to get the AGV as AllocationPoint and that extract it as an Object via this code:
AGV.AllocatableObject CP = token.CPs[1];
//check number of allocating agvs is bigger than one
if(Model.find(CP.name+">variables/allocations").subnodes.length>0){
    //find agv having the 1st allocation
    AGV.AllocationPoint allocation = CP.allocations[1];
    Object agv = allocation.allocator;
