Gui Vaccaro avatar image
Gui Vaccaro asked Gui Vaccaro commented
Dot syntax failing with tracked-variable labels
from examples and answers from the forum (e.g. https://answers.flexsim.com/questions/80701/graph-multiple-data-of-a-tracked-variable-in-one-c.html, https://answers.flexsim.com/questions/177837/performance-measure-from-tracked-variable.html) the following syntax should work to update tracked-variable labels:
myObject.myLabel = newValue;
or
myObject.myLabel.as(TrackedVariable).value = newValue;
However, as one can see below, the only working syntax is using the "labels" format:
myObject.labels["myLabel"].as(TrackedVariable).value = newValue;
It also fails when reading the variable content:
FlexSim 25.1.1
statistic collectortracked variablevalue
1 Like"
Felix Möhlmann answered Gui Vaccaro commented
Both examples you linked use Tracked Variables from the toolbox and the references point to the node in both cases, making it possible to cast the reference as TR and read the property.
Using object.labelName gets the value of the TR-node, a number, which can not be cast as a TR. You do in fact have to use the object.labels["labelName"] syntax to get the TR/Label-node and access properties of the TR.
Gui Vaccaro avatar image Gui Vaccaro commented ·
Hi, @Felix Möhlmann , thank you.
You are correct on your interpretation. My observation is about the incorrect syntax used in the previous answers from FlexSim. I could not find any explicit reference about this in the help files.
Thank you for the confirmation.
