I did a research to change my "Processor" color according to my global table STATUS from flexsim. However, I have quite a number of 'Processor' imported from different design models (.dae file) instead of build in "Fixed Resources" from FlexSim.
This is what I have figured out by changing the those 'Processors' color by clicking
1) Click on 'Processor1' (WDC_199)
2) Visuals > More Visuals
3) Customize the meshes in the selected 3D shape
4) Mesh > 'ID6'
5) Check 'Override' and select color from 'Diffuse color'
By using this model (model1.dae), now I want to integrate the color change by reading my global table as the data will be changing from time to time via process flow. Different "STATE" of the EQPID will have different colors. I have a custom code in my process flow to read my global table every 10 seconds.I would like to get advise on how should I achieve this requirement? Your guidance would be much appreciate. Thanks in advance.
Color Change.fsm
