Hi! I am trying to simulate a piping production proces. A pipe (or in the table a spool) always follows the same route but doesn't need every proces step. I put the production planning for a week in the source. In the table it also say for every spool if it needs to be sawed, bended, fitted or welded. If it has a 1 the proces happens. If a proces is skipped for example it does not to be bend, then the item should go from the saw to queue 3 instead of queue 2.
I think it is possible by using labels but I find them quite hard to understand and don't know how it should be done. If it is possible I would like to not use process flows.
Thank you in advance for your help!
