I'm sorry, this my file version 22.2 percobaan 1 (1).fsm
You can use the command to get about distance between A and B.
If these are distances on a network without any offset travel, then you can assign virtual distances for a network node network.
sorry this is not my homework, this model is just an example
@Dilla Da, I attach an example.virtual_distance_network_nodes.fsm
@Dilla Da if your first problem is resolved, please start another thread for the new question.
All objects using the network must connect to the network. The destination that mentioned is not connected to the network.
David
David
@Dilla Da Please look into the User Manual about Network Node. You should be able to explore more information about virtual distance.
David
13 People are following this question.
