new-innision-simulering-2_autosave - Copy - Copy_autosave_recovery_autosave.fsm
Hi everyone,
I’m working on a simulation that handles multiple products, each following different routes. I’ve encountered an issue with a specific product type: during one of the processes, I use a “move object” function to direct the product to the correct process. However, in some cases, the subsequent product (the one that enters the system right after) skips its intended process step and instead follows along with the first product. This behavior is particularly noticeable when going through OFM 2 with the first two products.
I’ve tried using zones to solve this problem, but it hasn’t worked so far. Any guidance or suggestions on how to address this would be greatly appreciated.
Thank you in advance for your help!
