Hi everyone,
I have a very weird problem. When I run the experimenter, it only does two iterations. It is supposed to keep running until it finds the optimal scenario.
FlexsimProj_05.04.2025 upd.fsm
Any help is much appreciated! :)
Hi everyone,
Also the objective function is just the variable parameter. So the optimizer did what it is supposed to do. It marked the iteration with the highest parameter value. Which is also the highest value it is allowed to pick due to the constraints you set.
What did you expect would happen with these settings?
11 People are following this question.
