Kevin avatar image
Kevin asked Felix Möhlmann answered
Performance measure from tracked variable
Hello.
I have a tracked variable that adds 1 when entering my simulation and subtracts 1 when leaving. With this I have a table on a dashboard that tracks the maximum number of entities in the system during my simulation run. I was wondering if there is a way to create a performance measure based on this tracked variable. I get these errors when I select my tracked variable and statistic by individual object maximum: 1743701754380.pngI am also running into some problems with my experimenter now that I am on FlexSim 23 (previously on version 19 and never had issues). It freezes up when I select my 1500 scenarios with 100 replications each and on the run experiment tab I just get a sad smiley face rather than the usual display of each replication. Figured FlexSim can not handle displaying 150,000 total replications, but now the software constantly freezes up and runs through my experiment extremely slow. Wondering if my 16GB RAM plays a role in this and higher PC specs would smooth this experience up a bit.
FlexSim 23.2.0
experimentertracked variablesperformance measure
With the reference field pointing to the TR, you can use expressions like below to get the maximum/minimum/average value of the variable.
reference.as(TrackedVariable).maximum
Are the scenarios defined as an experiment or range based job. The latter handles displaying large quantities of scenarios a bit better in my experience. Maybe try breaking it up into multiple jobs as well. And 100 replications per scenario seems quite high. Is the variance in the model really that big?
