Hi, I want to use AMRs for picking up sth and carrying them to a location by optimizing and evaluating performance(KPI) , if you introduce sources like an example related to this application, I will be grateful.
@N-111, an evaluation needs a suitable logic of acquiring AMRs first.
You can evaluate time of travel. Then you get results including blocked times.
You can investigate distance of travel. Then you get bad chosen AMR results, because you call far distanced vehicles sometimes.
You can look for waiting times, until a task gets executed first. Then you can notice that some robots always have to do something and others are just waiting.
10 People are following this question.
